boost bypass actuator
pontiacgt500
hey guys the middle barb was broke on the actuator and i know thats where i had one of the vacuum leaks, they had it superglued smfh. i know theres a way to remove the actuator from that shaft going into the supercharger i just cant figure how to angle it or whatever to remove it, does anyone have any tips or ideas to removing the BBA off of that shaft? thanks appreciate it
You got to rotate it all the way around and then twist the vacuum actuator off once the key is aligned... It's not hard really, just make sure you take all the movement (range) and it'll go. Move the butterfly rod too...
