BMR Sway bar bushing PN or supplier?
Haney GTP
Guys,
Just picked up a BMR rear sway, measures close to 23mm, advertised 22mm.
Where should i look to find the poly bushing? i looked on wbs, energysusp, and pfyc, as well as the usual vendor sites like zzp and intense, no one has 23mm or .905/.866" bushing size.
Help...
did find that Oriellys has .8" bushings. If stock rear sways are 17mm the .8 bushing should be way too big since 22mm=.866"...anyone use these bushings before??? i doubt they are poly, so probably not worth it, but if theyre cheap and they fit i might use them for a bit until i find poly bushings.
