Blower fan squeak Fix
JoshsGTP
I GIVES MONIEZ
OK guys here you go an easy fix for you if your fan blower motor squeaks,
First all you need is WD40
Then open the passenger door and look at the bottom of the dash.
Take the push pins out and the bottom cover comes down.
look at the bottom of the blower you will see a small hole in the middle spray the WD40 in the hole and the squeaking should stop.
graphite doesnt attract dust. its pretty good too. i think im going to use max film on mine, the wifes van is squeaking and the stealership doesnt want to do any work...lame. so much for a warranty!
I'm a fan of Boeshield and that is what I used on mine, thought that was like a year ago before I saw this howto...just followed the noise and sprayed away. I SWEAR by Boeshield.
