Blinking Low Coolant Light
kevinpope
Coolant level is good, but light keeps blinking. Temp on gauge never gets above 160. Could it be the cooland level sensor? If so, where might that be found?
Thank you,
Kevin
Yes it is the sensor, it is in the top right of the radiator, You can just unplug the sensor and the light will stay off, if you check your coolant everynow and then.
It is the only thing with a wire connected to it on the radiator. It is right below where the trans cooler line goes into the trans mission.
That was it. I guess when I flush the radiator, I will change it out.
FYI Mojodare - It is located on the back of the radiator, towards the top of it. I took my battery out so I could get a better look at it.
Thanks for the help 01GTP
