SomeDudeAtHome
So the vents on the drivers side blow hot while the passenger side blow cold. Common sense tells me that the drivers side needs replacing but common sense isn't always the way things work with these cars. Also is it the same part for both driver and passenger side or are they different. I'm only seeing one part listed on Rockauto. Figure I might as well replace both of them while I'm at it.
