Blend doo or Blend door actuator?
its the actuator, they turn the door.
take them off turn the little knob by hand, hot is one way, cold the other. it only moves like a 1/2 inch, dont try to force it.
you want a "blend door actuator". they are not cheap either. junk yard is the cheap/free even way to go. just grab 2 in case one dont work.
see how this one says w/manual controls. what do you have? [TABLE="class: main, width: 759"]
[TR="class: part0, bgcolor: #F0F0F0"]
[TD][TABLE="class: parts, width: 634"]
[TR]
[TD="class: left"][TABLE="class: layout, width: 555"]
[TR]
[TD]DORMAN Part # 604107 More Info {#16177412, 5137781AA, 89018395, 89018681}
Temperature Actuator (Controls the Blend of Hot and Cold Air); w/Manual Temperature Controls[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: right, align: right"]
getimage.php
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: right, colspan: 3, align: right"]$26.79[/TD]
[TD="class: center, align: center"][/TD]
[/TR]
[/TABLE]
if you pull your bad one out, its got a part # on it. match it up to be sure. and once yours old one is out you can turn the knob to cold but it will be full time cold. no heat unless you turn it back to heat.
