Best LIM Gaskets to Use on 3.8 GT
indygrandprix
I am wondering what the best LIM gaskets are to use when doing a LIM gasket Job.
My Car is an 01 GP GT and is 100% factory w/ 175k on it if that matters
FEL-PRO Part # MS98014T Was the most expensive ones on rockauto but that doesn't always mean they're the best. I was wondering what your experiences where. Thanks
Take your pick.. RockAuto or:
Intense:
INTENSE Racing: Lower Intake Gaskets (L36)
ZZP:
GM ACDelco - Intake Gasket #GM-89017825
RockAuto either set:
ACDELCO Part # 89017816
You might want to go ahead and swap out your black plastic upper intake manifold to while you have it off. From my personal experience (which maybe 1 in a million but....) after I redid my lower intake manifold gasket set I reused my black plastic upper and ended up hydro locking my motor when I started pouring coolant in because it was cracked. If you don't want to replace your black plastic piece I'd do what's described in the thread below.
http://www.grandprixforums.net/how-mod-lim-46931.html
