Best Intake set
tmull44
I'm sure this has to have been covered at least 100 times but who makes the best set? Gm or aftermarket? I have an 05 GTP S/C? Any part #'s and how about the elbow I've been reading about? Thank you for your help and advise!
I get the GM gaskets, not the ZZP ones. ZZP's never seem to fit the same as the actual GM lower intakes
Likely you need the SC gasket from GM as well.
Fuel injector o-rings from fel pro
TB gasket is reusable
Elbows...I've never had a bit of trouble with the dorman 47065 elbows. Apparently qwik did though. I never buy the GM ones.
