bayareagtp
i am looking for info on the best air intake . which ever kind it is home made or a kit you paid for . i would like to know what you guys think . thanks !
My intake is a 9" K&N open cone, to a 4" 45* bent piece of diesel exhaust pipe powder coated red to a LS1 MAF, then to a LS1 TB. Throttle response is just freaking awesome on my car.
~F~
wow I can't believe someone lit this wick so soon.
Just know that a properly installed CAI gives you the cold air of a fwi and a shorter distance for the air to travel like an open cone.
Downside to a CAI - price and the room a box takes up
Downside to an open cone - heated air intake, moreso on a daily driver.
Downside to a fwi - long way for the air to travel and the filter is exposed to more dirt and some have said water.
I run an AEM driflow filter and wouldn't use anything else.
It all depends on what pulley your running. I run HAI and i see more maff Hz from that than i do fwi. I run 2.8 pulley DD. If you have a 3.0+ pulley puting your filter in the fender isn't a bad idea.
But do the test for your self, go to the track, scan maff hz. let us know what works for your setup.
For me the HAI is the best....the headlight is removed at the track to help let in cold air.
I dont like the dry flo.....instead of sucking air through the main filter...it sucks it through a piece of foam. IMO...it doesnt offer great filtration. yes it will keep the water from being sucked up into the engine...but it eliminates most of the air being sucked in where the filter is....I dont see it filtering out most harmful particles.
this is just my opinion
I was running a Wizaired with a 4X9 Driflow through an 85mm (LQ4) MAF then into thin wall tubing and reduced before the 04 Series III TB.Rules are different for track and a daily driver.I will have to agree with Jason, you have to test to see what is best for your car and driving conditions. Also look to see what the high end really fast cars run or don't, cost not being a factor.
People often ask why their car seems faster when it's cold out. We know why.
I tested an open cone (again) last summer versus my cai and around town at 45 mph or so. The car was noticably slower with the open cone and intake temps never dropped down to the 1 -2 * above ambient that was afforded by the cai. I really wanted the open cone to be better because removing it would clean up the engine bay.
Anyone know what the fastest V6's at Branson had as far as mods go?
What I always wonder is how quickly the temps on a HAI come down when moving. My concern for my intake system is track use. Normal driving, I don't really care if a little timing gets pulled. If my track run is only 13 seconds, I'd rather have the IATs close to ambient the entire run. It was one of the reasons I went with an IC.Had a Thrasher, Wizaired, and HAI. I like the latter the most.
IATs only matter when its 140+F when it comes to timing. The only time I saw that is when I was sitting outside on a hot day with the engine running for 10 minutes while I setup my scanner. It quickly went down when I started to move.
As far as someone saying a FWI outflows a HAI, LOL. Thats about all I can think of.
