Best 12 switched power wire under the hood?
iowagtp
Looking to wire my ccfl halos up. I wired them to the secondary turn signal lights but they didnt supply enough power to fully light the halos up. Is there a place in the underhood fuse box to tap into?
When I put halos in my other set of headlights I ran power from the inside fuse block using a fuse tap to a switch so I could turn the halos off when I didnt want them on. I would suggest doing the same thing if you are willing.
Im not really looking into switching them on and off I just want them to come on when I turn the car on.
Alright. Just thought I would throw that option if you were willing to go that route. Since offhand I couldnt tell you which are switched I would suggest either using a multimeter or just getting a fuse tap and trying different spots with the halos hooked up to see where the power is. The only place I can tell you for sure that would have switched power is the fuse block in the car just because Ive used it before.
