Blue00GTcoupe
Hello,
I have been working on diagnosing this problem now for 6 months, fortunately the car keeps running.
I have had misfire code on cylinder #3, now I suspect after checking for intake leaks, vacuum leaks and finding none of either one, that its a lean fuel condition. The car runs fine as long as I don't push the throttle down more than 1/4 of the way. Past 1/3 down and it starts stumbling and 1/2 way down or more I get the late ignition backfire into the intake, which I think is a lean issue.
I tested the fuel pressure, and the book says that "normal" is 48 to 55psi with KOEO test on a NA 3.8 L, mine was 45 at best.
Idling, mine was at 39 psi, giving it a good rev in park, it maxed out at 49 psi. It did jump up on the pressure nice and quick, I will say that.
So how do I narrow down the problem without changing a bunch of un necessary parts? :th_nervous:
Thanks for the help, for any yahoo's out there who reply.
BTW: I changed the filter on the tranny at 135k miles over the winter and filled with Amsoils ATF, and found the old filter was totally blocked. When I went to pull it, not a drop was coming out, then a huge gusher once it was off and out. Probably a good idea to change that filter, don't just do the reverse flow jiffy lube method.
