Tengis
Ive asked people in the Grand Prix community directly but everyone keeps telling me to switch to the 98+ PCMs (which has better knock recognition stuff). When I was running a mid 12 second supercharged setup I never had any issues like this. Randomly one day it appeared and its been here since. Something electrical, mechanical, spiritual... . No idea. Ive eliminated pretty much EVERYTHING that could be physically tapping on the motor to create false knock.
The problem is at VERY low throttle percentages (1-2%) I get knock (typically less then 1 degree) but sometimes as high as 5-10 degrees of knock. I threw in a couple gallons of race gas and the knock was still present so Ive ruled it out as false. At WOT I seem to get completely random knock (which could or could not be related to the partial throttle knock). I get knock as low as 7psi (limited by the spring in my waste gate) which is very little boost.
Did a compression test came back good. All cylinders read 130-135 after 3 seconds of cranking, all cylinders read 160 exactly after 5-6 seconds of cranking. All of my plugs looked slightly white when I pulled them. Running lean? According to my wideband Ive been running pretty rich for the last month or so at WOT (mid 10s).
Went over a bunch of my wires again and actually found some wires in the back that were rocking back and forth and the shielding was melting on my rear manifold. Its the wires that go down the back of the motor to the sensor on the diff cover and to the knock sensor.
Anyway, went out and drove around thinking that it couldve been the cause of my partial knock and possibly some of my WOT this whole time but it wasnt. Still have it... and my car still seems to knock at WOT with only 13-14psi and 16.5 degrees of timing. Im running a high 10 to low 11 AFR right now.
Threw a code for my crank position sensor the other day so I went in and replaced it and did a case learn with my tuning software. Knock was GONE for a day or two except blips of .01 at partial throttle sometimes. Over the course of the last couple of days its been slowly returning... maybe Ive got a stretched timing chain? Im running an aftermarket "unstretchable" double roller timing chain so Ive been scratching this off.
Ive got a setup capable of 18-20psi with a pretty big intercooler. Running 65# injectors, aftermarket racetronix pump, a pretty big cam... and at wide open throttle its verified by my wideband that Im not going lean or anything which could be causing it. Ive replaced all O2 sensors and a ton of sensors on the motor since I had a lot extra (MAF, TPS, IAC, knock sensors, MAP sensor).
Ya, I know you guys arent use to working with my stuff, but I figured Ide copy and paste and see if anyone had some insight.
At wide open throttle its verified by my wideband that Im not going lean or anything which could be causing it. Ive replaced all O2 sensors (including wideband) and a ton of sensors on the motor since I had a lot extra (MAF, TPS, IAC, knock sensors, MAP sensor).
:th_scratchhead::th_scratchhead:
