BCM reprogramming.
Slick2500
Active member
I can't seem to find out how to redo the BCM so that when you shift the car into park the doors unlock, the manual for my 01 GT had the instructions for doing this, but my GTP's manual does not. Could someone post the instructions here for me?
I thought this was an option after a certain year, possibly '00... If your car supports it try this:
Its relatively easy.
Turn the ignition to Off (the spot where you'd pull your key out)
Pull the Mall PGM fuse from the box.
Turn the ignition to Accessory (1 click counterclockwise from Off, or to the left)
Push the Unlock button. You'll hear a number of chimes corresponding to the setting your car is in, the factory default is 3. Push the Unlock button once more to move the setting to 4 and you'll be set.
Ok sweet thanks, yeah the manual for my 01 GT had how to reprogram everything in it, I tried googleing that but didn't find what I was looking for.
