A98GTP
My bbv shaft is rubbing on the solenoid and occasionally sticks. The other side of the solenoid is snug against the fuel rail. I have tried to use a screwdriver and create a little space, this works for a few days and then it starts sticking again. Is there a way to correct this or do I need to just replace it and will a new one do the same thing? It also appears to be adjusted all the way could this be why it takes forever to get into boost? I have to get into some pretty high rpm's but it eventually gets to full boost. I don't see any lego blocks till around 4500 rpm.
