Battery not charging
domgiants
I have a 2001 GTP and I recently replaced the lower intake gaskets. When I put the alternator back on I forgot to connect all the alternator wires. The car started fine and then I noticed the thick alternator cable was starting to spark.
The issue is the battery is no longer getting charged, I replaced the battery and had the alternator tested at two different places and I still have the same issues. The alternator tested fine and all the car accessories work so I did not blow the fusible link, plus all the fuses are good.
Does anyone have any suggestions?
