SyntheticShield
Someone tell me how to remove that frickin' thing. I cant find a write up anywhere. I see some retainer rings on the gear side, but I have not been able to work them free yet.
Really? Why then do they call it a 'balance' shaft if it does not figure into the balance of things. I would be curious also to their explanation of why when you have the crank 50% balanced it is recommended you remove the balance shaft.
I dunno, maybe my understanding is way off but Im not sure about that statement from them, but Im open to the idea that I havent a clue what Im talking about either and am way off base.
But, the inherent design of a V configuration motor is that you need something to counter the forces of the up and down motion of the pistons. Engines like the boxer and rotary wouldnt need any balancing because they are naturally balanced by their configuration. Unless there is some other counter balance in the engine Im really baffled by the zzp statement.
Hopefully someone will come in and clarify everything.
