05 Comp G
Been driving for a couple months with ABS, Traction, and BRAKE warning lights all on. Started as just ABS and Traction intermittently coming on (shutting off when I restarted the car) then when when they were solid and not ever turning off the BRAKE light joined.
Finally made friends with someone that has a computer to read brake codes and it came up Front Right Wheel speed sensor.
Replaced the hub on that wheel but the lights are still sticking around.
Shot some WD-40 onto the harness to try to clean it out and although I don't totally understand a multimeter, I was about to get some sort of reading through the harness while the ignition key was ON.
Finally realized that there were actually 2 codes that came up on my buddy's scanner:
C0121 Valve Relay Circuit Malfunction
C0040 Right Front Wheel Speed Sensor Circuit Malfunction
Tomorrow I'm gonna rip a harness from the Pick N Pull just to be certain it's not just a bad connection, but that C0121 code has me worried, am I really gonna have to drop ~$400 on a new module?
