got a dilema. mods in sig except im using an M5 nozzle for alky. i cant remember what my commanded AFR is in the Base PE but either its 10.5 or 11.3. i did a 15mph roll with the outside temps ~70*F.
my IPWs were averaging 18mS all the way from 1st to bottom of 3rd gear. timings set at 19-20*. i zeroed out my PEvsTime table to prevent the pcm from adding fuel, eddie IIRC zeroed out my AFRvsRPM a while back. top of 2nd gear in the 10-10,500hrtz range i get 2-5* of KR going into 3rd gear. my o2s via NB were between 980-995mv
my WB is 10.0 and richer on the PLX wb. my AE enrichment i have increased from 75-80% at 130.33, 80-90% 132.33 and 90-100% at 135.33. the stock values is 128.33.
a few nights ago, i ran virtually KR-free with less fuel at 20* but WB was showing 10.0 and richer, then the day after when i ran at the track i got tons of KR and WB still displayed me being rich. bare in mind the O2s were still in the 980+ range.
what am i doing wrong with my tune? im about to turn off the alky controller and tune w/o it and see if i can do better. however i did try tuning w/o it and i could only run a 3.0/3.1 pulley with only 16* of timing at ~11.2, any more timing added i get knock, even if i add more fuel i still knock:th_shakinghead2:
sorry for the long tech-story but i wanted to let out as much detail as possible. if u can help and/or give some advice i'd appreciate it:th_nervous::th_peaceout:
