jessiinicole
Hello people’s, to quickly summarize my issue.. “Sorry for the autobiography on my car, but since I bought it”..
First- After 3 months of official ownership, the head gasket blew, heads went to machine shop, radiator got flushed of ALL the engine block &**T put it all back together start it up did not idle right had a little miss, mechanic put transmission Fluid!!! in engine he says to seal pistons or rods, after compression test?? I think that’s what he said.. Nonetheless drove good just idled bad. Check engine comes on giving code PO303 so changed the ignition wires (Napa). Ran really good next day check engine on yet AGAIN, now 2 codes PO341 and PO300. Since then Camshaft sensor was changed out and New Napa Plugs.. Still to this day has a slight miss in the idle at times when I start the car, but will (usually) level out after driving – super bad on GAS.
Second- Some time later, and please don’t laugh….I accidently drove about 18 miles in 3rd gear.. (not paying attention) luckily I caught it in-time before serious damage, after the fact my boost got stuck on 6-7 bars, RPM's jumped/ revved up to 5,000 + when getting into it to pass? Car died a few times the exact afternoon after this had happened, but thankfully had stopped same day. I checked…. and ended up needing to add 1 ½ courts of Trans Fluid. Check engine light came on with code P0121 when I cleared the check engine light it ran fine again, except for the fact my boost indicator doesn't work at all now...?? Until chk engine comes back with code P0121, but then it is stuck at 6-7 bars!?! This all took place roughly about a month ago..
As of right now No Check Engine, but I still have the weird idle when I start up sometimes? Also this morning while in performance shift trying to haul ass from green light my car wanted to leave good BUT once I got to about 4,000 rpm’s that was all she wrote let off the gas car kicked backed down, disengaged performance shift, drove normal, (if I am on the interstate driving or driving period and get into her she hauls ass, but dead stop taking off she doesn’t perform right? Just this past Sunday I got a misfire code, and cleared it! I continue getting random misfire codes MAINLY P0303, P0341, AND P0300. It is driving me nuts :th_angry-cussing:and I am not as mechanically inclined as I would like to be.. Could anyone help me understand my issues
- Just a girl
- Just a girl
