JJ91284
I went to start the gtp this morning and it wouldn't even sputter. First thing I check is the fuel rail, and no gas came out when I hit the bleeder. I checked all the fuse and they all look ok. I then did the fuel pump resistor test by bending the relay tab which should kick the pump to high and still I have no fuel pressure. I believe I need a new fuel pump. I'm going to check the pump first and make sure its getting voltage back there.
What pump do you guys think I should go for. I'm thiniking either going with a new stock fuel pump, or migrating over to the racetronix fuel pump with the harness. How reliable is the prj racetronix kit been. I've heard great things so far about it, but their probably aren't many people with more than 50k on the pump yet.
I called my local GM to see what a stock pump cost and they told me $550. I checked gmpartsdirect / paceperformance and they are around $350. My local autozone/advanced auto have them as well and are $350 or so but I question the quality of their parts. I'll probably go with the racetronix kit.
