Moozery
Was driving in about 20 Celcius rainy weather today when suddenly my RPM, temp, and fuel gauge all dropped to zero, and I got TCS and low fuel messages, as well as my DIC screens all turned to errors. At that exact same moment, my OBDII bluetooth scantool lost connection as well.
Restarted the car, fixed everything for about another 5-10 minutes and it happened again, and that's exactly how it's been happening since.
I was figuring my (stock) PCM took a dump or my new ODBLink scantool was causing issues, but from the searching I've done on here it kinda sounds like symptoms of a bad CPS, though it just seems like a lot of things to be affected over just a crank sensor. Although my car can be a real pain to crank in the morning after it's been off for a long time.
Possibly related, over the past week I've developed some really random and sporadic KR readings, mostly part throttle, was thinking they were just false or something. I actually got a negative KR reading of -0.1 about 10 minutes before this first happened today. Filled up with 94 today instead of my usual 91, but didn't change at all.
What's your guys thoughts? Going to avoid using the new scantool for tomorrow just incase.
2004 GTP
180 Tstat, TR55IX NGK's, open cone intake, 74k miles
Cruise control works, speedo and HUD work, interior electronics are fine
2004 GTP
