comongoose
So as some of you may know I am currently in the process of putting an L26 bottom with an L67 top into my car. Right now I am a little past the mid-way point, as today I had got the valve train on and the lim torqued down, with the motor on a stand. Me and my buddy then decided to get a quick idea of the compression at this point. As he spun the crank, I put my finger over the spark plug holes to feel. The bottom end has 26k miles on it and the rings are mint. All the cylinders held pressure very well, except for the back two on the opposing heads. The head in the front was the worser of the two. I could hear a hissing sound coming out of the LIM as the crank compressed that back cylinder. The back cylinder on the other head was not as loud but I could also hear a little air escaping as well. I am guessing there is a problem with the intake valves on these two cylinders. I am on a budget with this car, and I need to know how bad this is? Do I need to tear it apart again and fix the heads or should I just rock the motor as is. Also does my half-ass test while on the engine stand have anything to do with it? When this is all done I want the car to be reliable, at the same time I am getting eager to finish and running out of money. Any input will be greatly appreciated. Thanks in advance.
