Back Deck 6x9 R&R
1bad2004GTP
I have indepth system knowledge but never done these particular ones. It appears the package tray has to come out. How much other interior need to come out? I just hate removing any more plastic than I have to, because it loves to break. Already have had to replace several pieces. Now have to replace one speaker grill because clips broke when trying to remove, even with trim tools.
You remove the rear seat completely. The bottom has two little pull tabs on hidden about 6-10 inches in from the door...one on each side...then the back has 2 18mm nuts to remove the seat belt buckles, and 2 10mm nuts holding other brackets. Then lift the rear seat straight up toward the back window to release it from it's latches. The parcel shelf is just push pinned in once you get the seat out. There are 3 of them...then that pulls straight towards the windshield. Then you're at the speakers. Good luck!
