97gprixgtp
Hi all, I have a 97 gtp and am having issues with the pass. axle. It seems that the inner joint continues to slap the engine cradle from what I can tell. With the wheel off all looks normal but put it on the ground and it is hitting somewhere. It slings the boot right away and the axles last about 6 months. I made the mistake of having someone do the first one but the 2 after I have done. The car does not seem to lean or sag to that side and nothing looks bent. The only info I can find is the compressed length between the sc and non-sc axles. Is the joint different on the inner? I do not know if the right axle was originally installed and that maybe by ordering the same part number I have been getting the wrong one over and over, or if the rebuilder is using the wrong or a generic joint. Any help is certainly appreciated as I am stumped. Thanks, John
