Sandman
I had a leak from the driver side axle. I replaced the seal and thought that would solve the issue, well I was wrong. It still leaks. What I need to know is that are there any other seals that could leak and look like an axle seal, the fluid is definitely coming from the seal area though. Also if the axle shaft is worn what is the correct size of the axle to determine if it is undersized or not?
