i just installed my 2nd set of front wheel hubs, problem with the first ones were the company did not provide a pre-load torque value so I just torqued to the factory 120, which i later find out is way too low for the cheap-o bearing assemblies. The new ones come with a nice box and have a little card that says they "differ slightly from OEM and need to be torqued to 180 ft/lb" It was good for a few days, but after a good run on the highway i get the click click click sound of an under torqued bearing while slowing down and my abs/trac off/svs lights kick on. Same issue i had with the old bearings, but I broke the abs wire off one of the old ones so i returned them:th_tongue2:. The clicking goes away when i grab a torque wrench and crank them down again but I have to do this every week or so:th_scratchhead:
Should I pull the nut off and use loctite?
Is there any step I missed? Ive heard some people say you need to grease the splines on the axel, I cant see why but I never did this.
Also, are you supposed to torque the axel nuts up on a jack or with the weight of the car on the wheel? does it matter?
