Avt-852 (dhp)
jwach
I talked to Matt at AVT and he has the equipment new for the DHP software. However he asked if I wanted the L model, which includes wideband functions, or just the default E version. Have any of you guys ordered from him? If so what one did you pick up and how did it work?
the wideband functions is the analog to digital converter that is the small green connector on the side of the box it allows for additional 0 to 5 volts inputs for data logging. you will want that if you are doing this for making reliable decent power
I have the 852 L as well I like it and for the additional 3 inputs to log anything I want to that is 0-5V so if you wanted to run temp sensors for IC or monitor Crank case pressure it's pretty easy. I haven't used them yet, but they are easy to select and connect to the DHP software.
Jeff
