keenan00gtp
what does this do besides keep me cool? worth 90$? worth anything?
For my hoses to and from it, I'm using stainless steel braided FUEL line from Summit.
There is definitely temp related values. The temp sensor isn't in there for ****s and giggles. I remember the quote you're referring to from Trannyman about the big diesel.
If I remember right, the TCC won't engage lockup unless above like 80* or so. I remember experiencing this first hand a couple winters ago when I would let my car idle to warm up temp before driving. The trans would not engage lockup until several miles down the road since it was still cold, and I believe Trannyman said that was a feature.
Shouldn't be a problem for me at all, but I have to wonder about some who live up north. I also thought I saw that setting in my Powrtuner somewhere.
My trans TC locks up once the trans temp gets above 77°F, everytime.
Again, just my thoughts, so take it for what its worth. But I think yes, you can get your tranny temp too cold. But as long as your temps are above 80°F and below 200°F, you should be fine.
And I have not found the setting for the trans temp TC lockup in the PT.
True, but like I said I have to wonder about anyone living far north. How warm do you think the tranny can get in sub zero temps with its own cooler?
Where are you installing it? Unless its in the tranny pan where the stock temp sensor is it won't be totally accurate to everyone else's readings.
You don't have a way to get the value from the stock sensor?
