Auxiliary Electric Fan
mnewsum1
I need some help on how to install an auxiliary electric fan for cooling purposes.
I understand the push, pull of the fan for cooling purpose but do not know how
to wire it up to a toggle switch. Thank you.
buy a fog light wire kit, comes with a switch, a relay, inline fuse and all the wire you need. run the power side of the switch to a ignition on only fuse in the fuse box, this way it turns off when the cars off. but you can still turn it off and on when the car is running if you want to.
