Silver2kgtp
AutoTap OBDII Diagnostic Scanner with enhanced GM parameters.
Used this alot while driving and to log my runs.
All wires, cables and disc are included. Serial number and activation number is included. Also come with original case. Can be used with a laptop with a serial port or with the Palm
- Palm M505
- Extra New battery for Palm
- USB charger and Sync craddle
- Aluminum case for Palm
- Palm to serial cable
$85 shipped
Here is some info
Good Autotap review with pictures
http://www.batauto.com/articles/AT/palm/
Link to the Enhanced Parameters for GM
http://www.autotap.com/enhanced_parameters_gm.asp
CURRENT APPLICATIONS:
- 1996-current ODBII-compliant vehicles
With all their computer controlled complexity, today's cars require more than a normal toolbox to keep them running smoothly. Computer controls and a vast array of sensors require today's mechanics to have access to all of the information going on inside the car - whether they work at a dealership, small shop, or their back yard. Are you frustrated because you want to know what's causing the “service engine soon” or “check engine light” to come on, but you can't seem to pinpoint the problem? Or are you wanting to see how your car is performing and want to “tune” it for maximum performance? Now you can access the same information as the dealership mechanics. Use the AutoTap scan tool and your PC desktop or laptop to monitor real time data from the sensors on your car, as well as read and clear Diagnostic Trouble Codes. AutoTap is an OBD II scan tool that works on 1996 and newer cars and light trucks. It converts your vehicle's computer and sensor readings into the format that your PC understand. You can view, graph and record live data... and turn off that annoying “Check Engine Light”!
AutoTap connects the ODB II data port located under the dash of every car dating back from 1996 to present, to the RS-232 serial port on the back of your computer. Monitor and record parameters in real-time using a number of graphical and visual displays. Export the recorded data to be viewed later through a spreadsheet program.
AutoTap OBDII diagnostic scanners let you tap into your engine's inner secrets. AutoTap's included software turns your PC's screen into a virtual dashboard for real-time sensor parameters and lets your PC's hard drive log virtually unlimited performance data on your vehicle. AutoTap gives you access to hundreds of Diagnostic Trouble Codes (DTCs), real-time parameters, and powertrain data. Any vehicle manufactured after 1996 is OBDII compliant. To make sure that your purchase is future-proof, AutoTap is Controller Area Network (CAN) compliant. CAN is mandated by the EPA in all new vehicles after 2008.
Features and benefits include:
* Create your own virtual dashboard
* Supports all domestic and foreign OBDII vehicles after 1996
* Read diagnostic trouble codes for rapid troubleshooting
* Turn off your check engine light
* Diagnose bad oxygen sensors
* Prepare for your EPA emissions tests by reading 11 critical monitors
* File logging and playback
* Capture freeze frame data
- Palm M505
$85 shipped
Here is some info
