ELECTRICxWIZARDx
'01 GTP, no mods, 153k mi.
Few days ago i replaced my radiator due to a cracked tank. Dropped in a new Spectra Premium branded radiator. Coolant maintains proper level now, but have run into another problem. The lower trans cooler line is leaking where it meets rad.
Rad came with new threaded fittings i installed into rad. Had some yellow stuff on the threads, presumably sealant, I put 2 wraps of teflon tape around threads as well before installing. Been keeping an eye on stuff looking for leaks, and saw ATF on the core support grommet. Pretty good drip down the plastic lower pan, onto the frame rails a bit too.
Today, i gave the fitting a little more torque, thinking maybe it was just loose. Cleaned up bottom of car to make spotting leaks easier. Went for 15 mile drive to warm up ATF to check level, as specified in the owner's manual. Park, shift through all gears, back in park, check ATF with engine running.
ATF is showing on the dipstick all the way up to the curly bends on the dipstick! Looks bubbly too. What would cause this?
Leak looks pretty substantial, cleaned up bottom of the plastic pan, frame, pretty much everything i could get to with car on ramps this morning before drive to warm up trans. Pretty messy again after 15mi cruise on highway. Can post pics if needed.
I did notice while leaving the house, that it seemed to hold 3rd longer than usual [5-10 sec] before kicking down to 4th with cruise on at 65mph. So, what's my next step here?
