have a 2000 regal gs that has a rough surging, bogging idle when I first start it. It's bad enough it will die if it is in drive. I can rev it to 1200 rpm for a minute or so and then it settles down into a decent idle like there was never a issue.
Runs fine after that. If I kill it, it will do it again hot or cold. I can then rev it to 1200rpm for a minute and then it is fine again. It makes a huge sucking sound while it isbogging and surging. Huge sucking sound goes away once it gets to holding a steady rpm.
I have tried several mafs off running cars they all do the same thing.
Engine was replaced with a low Mile unit and has ran great since it was put in. A case learn was supposedly not done when they did this. It seemed to run fine since the swap. And these symptoms don'think seem to be case learn symptoms do they? It is not showing any codes. I have checked for vacuum leaks but do not see anything Or hear anything when sprayed around with carb spray
Any suggestions?
Any suggestions?
