at what pulley size do i need new injectors
copperpacecar
SexyStudmuffin
as the title states im curious as to when i gotta switch out these stockers. i got a 3.1 pulley going on this week and it only just struck me that i may be getting close to my injectors limits with this pulley. if i am what injectors do u suggest i get
with a properly working fuel system, you typically run out with a 3.0 Pulley. That being said every car is different, and the only way to know for sure is to scan
Sorry to thread jack, but since we're on the topic...any idea at what pw the stock gtp injectors max out before going static?
once you start hitting 21.xx+ IPWs then youre close to maxing them or you already have. however, unless youre knocking then you should be okay.
I ran mine down to a 3.1"...and the injectors weren't running static but I had no IC OR Meth...I started to knock so it went bye bye and back up to the 3.25"
