    TIPS:
Assorted grand prix parts for sale.
EdwardK44
I am selling all my old parts from my 06 grand prix gt. These prices are low and i would like to get rid of all of this. Pictures are to follow.
Ac delco mass airflow sensor: $25.00
Boost bypass valve: $20.00
Boost bypass solenoid: $20.00
Gm strut tower bar: $20.00
Fuel pump used from 06 grand prix gt: $65.00
Moog poly sway bar bushings 34mm: $10.00
Moog front and rear trailing arms: SOLD
L32 3800 throttle body with gasket: $60.00
ZZP rear 02 sensor extension: $10.00
180 degree t stat: $10.00
195 degree t stat: $10.00
3 bar map sensor: $40.00
3 new ignition coils: $60.00
M90 Gen V supercharger gasket: $15.00
Crankshaft position sensor: $20.00
Camshaft sensor: $20.00
Evap solenoid for n/a grand prix: $20.00
Evap solenoid for sc grand prix: $20.00
Two 3.8 M90 supercharger pulleys: $20.00 each
GM snout seal and bearings: $30.00
M90 Supercharger vacuum tree: $10.00
GM supercharger coupler: $10.00
Two pcv valves w/springs: both for $5.00
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171735_zpskrncu5d4.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171732_zpshjhqicml.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171730_zpskijd26eo.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171725_zpsbbatxqr7.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171717_zps4b4bmee5.jpg? w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171714_zpsrfbv6fhu.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171713a_zpsipmnedtg.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171710a_zpsubbyevro.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171709_zpsie1cg4bl.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171708_zpseqan7dqr.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171706_zps0hoqeca4.jpg? w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171704_zpsgt67nrkr.jpg?w=480&h=480&fit=clip
http://rs1070.pbsrc.com/albums/u499/Edwardk44/0408171703a_zpsjruefi4v.jpg?w=480&h=480&fit=clip
Heres the mileage on the parts
Ac delco mass airflow sensor: 140,000 miles
Boost bypass valve: 140,000 miles
Boost bypass solenoid: 140,000 miles
Gm strut tower bar: 3,000 miles
Fuel pump used from 06 grand prix gt: 140,000 miles
Moog poly sway bar bushings 34mm: new
Moog front and rear trailing arms: new
L32 3800 throttle body with gasket: 140,000 miles
ZZP rear 02 sensor extension: new
180 degree t stat: new
195 degree t stat: 140,000 miles
3 bar map sensor: 140,000 miles
3 new ignition coils: 1000 miles
M90 Gen V supercharger gasket: 140,000 miles
Crankshaft position sensor: 140,000 miles
Camshaft sensor: 140,000 miles
Evap solenoid for n/a grand prix: new
Evap solenoid for sc grand prix: 140,000 miles
Two 3.8 M90 supercharger pulleys: 140,000 miles
GM snout seal and bearings: new
M90 Supercharger vacuum tree: 140,000 miles
GM supercharger coupler: new
Two pcv valves w/springs: 140,000 miles
