Are these heads bad?
Like said looks like a casting flash. I dont think the heads would crack all the way up there if they were going to crack.
Agreed on the casting flash, but you might want to let Morad know what you found, just in case. If it does turn out to be a crack that causes problems, you'll be able to prove it wasn't your doing.
casting flash, nothing to worry about in most cases, however i grind and cleanup the pushrod area's when do a teardown as occasionally the casting will hit pushrods on modified rockers
