are stainless steel break lines worth it?
asite57
are SS brake lines really worth $115 bucks? im upgrading to a 12" brake kit and i could use the money else where
i just bent the bracket out a lil to give the stock lines more play, only reason you would 'need' them is because they are longer, so i just made mine reach for free.99
your talking about the bracket on the car where the rubber line meets the metal line? you just angled that a little and it worked well for you?
yes on the inside wheel well, all you need is like an inch, i bent them out a little with no problems...on 2 cars actually
i bent the tab that holds the line as well. also turn the wheels all the way and reach in there to feel if the line is hitting the tire, if so twist the line one way or the other on the caliper banjo bolt there, to move it away from the tire.
i had mine set, then got new tires up front and had to move them again.
