Turn ignition key to on (but don't start engine) and leave it for 10 seconds, then turn it off for 10 seconds.
Then push the pedal down as far as it will go, turn ignition key back to on for 10 seconds again, then turn key off, then release pedal and wait another 10 seconds.
Repeat this 2-3 times to make sure it's got it. If you have a scanner you can verify it. With the ignition on and foot off the pedal it should now read 0% throttle, then push it down and the percent should rise until you are at 99-100% at WOT position.
