Any one running SSC springs with pacesetters?
GotMelon
Like the title says if so I was wondering if the exhaust hits. Thanks
Did my post confuse you? BLAME AUTOCORRECT!
hits where? the ground? speed bumps?
it's going to be very hard to make that happen unless you're driving like a noob. there's lots of ground clearance, even being lowered. your lowest point is going to be the downpipe and cat area.
Sorry I was half asleep when I posted. I ment hit the floor borads due to having to put Spacers on the engine and transmission mounts from SSC springs as from what I read you can't use shorter dog bones correct?
Lowering springs doesnt change were the exhaust sits in the car but when you add motor mount spacers you are raising the motor up to correct for axle geometry.
Those spacers are only 1/4 to 3/8in thick and not enough to move the rear header/downpipe close to the firewall.
Shorter dog bones don't help, they just push the front header into the fans.
