another addition to my airbrushing
whitcomb
just finished these up for a member...
I think I just....well anyways. I am going to have to get my friend to airbrush some thing for me now. thanks a lot, haha. jk.
Looks awesome though.
Thats a reallly nice job you did, how much do you charge for this ? cause i want it done just like this but in red. I just want my fuse cover done.
I love the real flame thing. You do hellaciously good work. If I ever need anything done, I know where I'm sending it. Are those set to match the car color?
thanx for all the great comments!!! the color of he car is white.. hopefully when he gets them hell put up some installed pics for us!!!
Looks really good dude. I like the fact that the front valve cover was filled prior to the painting. I have seen paint work done with a unfilled valve cover, and IMO the grooves are a real eye sore.
~F~
yea that was the first one i filled and i def agree with you on that farns , filling them is def the way to go, i think the lines make the cover looks smaller for some reason..its hard to tell but i put a bevel also around the filler hole ....
Ya I can see your bevel, though yes tough to see with there being so much action on the cover with the flames.
When I fill mine...I tried to keep it as much of a sharp angle around the filler neck as possible. Just goes good with the sharp angles of the edges. That, and if the filler is not reinforced, I don't want it too thick, cause there is a good chance it could break out on you.
~F~
i used kitty hair(mix of fiber glass and bondo) to fill and then normal bondo for the finish.. you want use the least amount of bondo as possible cause it shrinks and cracks very easily...
I don't mean to hi jack, but here is my art work on the
Wizaired cover. This is made out of aluminum, and then
sprayed, then painted, the 5 coats of clear.
Your's looks really good as well. I am making a fuse cover out of aluminum as
well, and I will be polishing it, or brushing it. I have not decided as of yet..
yea im still learning.. its funnyyou posted cause ive stared that pic forever . im still trying to get the true fire thing down!! alwell practice practice..
