Tony Mendez
Uh Oh. The Malfunction Indicator Lamp (MIL) is on and you've just found a misfire code. It's a code P0304 which tells you cylinder number four is misfiring. There are no other codes and the engine has a steady miss. Now what?
Misfire diagnosis in this kind of situation should be fairly easy. You have a code, you know which cylinder is misbehaving, and you can hear and feel the misfire. The cause has to be one of three things: ignition, fuel or compression.
The hard-to-diagnose misfires are the ones that come and go and don't set any codes. These are the ghosts that can drive you nuts. Fortunately, the supernatural has nothing to do with the problem. The underlying cause is still ignition, fuel or compression related. The challenge is pinpointing the cause and correcting it.
Intermittent misfires are often caused by a weak spark or a lean fuel mixture. That piece of knowledge may not tell you what is causing the misfire, but it should help you plot a diagnostic course in one of two directions.
Random misfires are another type of misfire that can be hard to nail down. Random misfires that jump from one cylinder to another may be caused by a lean fuel condition or a weak spark. The challenge here is figuring out what's upsetting the fuel mixture or robbing the spark. The underlying cause is often a vacuum leak in the intake manifold or behind the throttle body that allows unmetered air to bypass the airflow sensor. Lean misfire can also be caused by an EGR valve that is stuck open or is not closing fully.
[h=5]Tracking Misfires[/h]No engine fires every cylinder 100% of the time. Misfires can occur at idle, when the engine is pulling hard under load, at high rpm and during throttle transitions as the air/fuel mixture changes. A few misfires are to be expected under these conditions, and should cause no major performance problems or significant increase in emissions. But if the misfires get out of hand and occur too often, they can make the engine idle or run rough, stumble when accelerating, waste gas and fail an emissions test.
On 1996 and newer vehicles that are Onboard Diagnostics II (OBDII) compliant and have misfire detection, the OBDII system tracks and counts misfires. The misfire monitor runs continuously when the engine is running. On most applications, the OBDII system uses the crankshaft position sensor (CKP) to look for subtle changes in the speed of the crankshaft between cylinder firings. If the crank suddenly slows a bit, it indicates a misfire. The only problem with this approach to detecting misfires is that driving on a rough road sometimes fools the misfire monitor. Consequently, some OBDII systems are programmed to temporarily ignore "misfires" under road conditions.
On some vehicles, the amperage of the spark current is analyzed when each spark plug fires to determine if the mixture burned or not.
When the OBDII system detects a misfire, it stores operating data such as engine speed, load and warm-up status. While the misfire is happening, the OBDII system is supposed to flash the MIL lamp once a second to alert the driver. Because this might distract the driver from her cell phone conversation, sipping her Starbucks coffee or yelling at her kids in the back seat, the OBDII system will set a temporary misfire code after the second such occurrence. From that point on, the MIL lamp should flash every time the misfire returns. If the same thing happens on the next trip, the MIL lamp should blink as before and remain on even when the misfire ceases.
If the misfire problem has gone away and does not reoccur on the second or following trips, the OBDII system may erase the temporary misfire code and forget the entire episode. The code may also be erased if no misfires are encountered under similar driving conditions during the next 40 drive cycles.
Knowing this, you should always look at the history freeze frame data when diagnosing a misfire code. If the code set when the engine was cold, chances are the OBDII system is being overly sensitive and there is no real misfire problem. Check for any technical service bulletins (TSBs) that may be out on the vehicle for false misfire codes. The cure, in many instances, is to flash reprogram the PCM so the OBDII system will be less sensitive to misfires.
On some cars, (Volkswagen, for example), it's possible to set false random or individual misfire codes when doing a cranking compression test. If this happens, just clear the codes after the test so the MIL lamp doesn't come on later.
[h=5]Quick Diagnosis with a Code[/h]On OBDII cars, the OBDII system will not only identify misfires but also coil and injector problems. Consequently, if the MIL lamp is on and you find a code for a misfiring cylinder and a second code indicating an injector fault for the same cylinder, bingo, the engine probably has a bad fuel injector. Likewise, if you find a misfire code for a cylinder and also a code indicating a coil fault for a multi-coil distributorless ignition system or coil-on-plug ignition, you can probably bet on a bad ignition coil.
In cases where there's a cylinder misfire code but no other codes, the ignition or fuel delivery system may be borderline and not yet bad enough to set a code of its own. A shorted or open fuel injector solenoid, or a shorted or open coil will usually set a code, but a dirty or weak fuel injector or a weak coil probably won't set a code.
Bad spark plug wires are a common cause of misfire codes. After 50,000 or so miles, the OEM wires may be leaking current to ground or other wires, shorting the spark before it can reach the plug. Also, internal resistance may be increased raising the required firing voltage to the point where the engine may misfire under load. Check resistance and if it exceeds specifications, replace the wire set.
[h=5]Scoping it Out[/h]An oscilloscope is a good tool for identifying and analyzing misfires, but using a scope takes some know-how and experience. Suffice it to say that anybody can "see" a misfire on a scope, but figuring out whether the cause is ignition or fuel requires an understanding of ignition waveforms.
Once you've identified the problem cylinder, you can look at the primary and secondary patterns for that cylinder to get more diagnostic information. The dwell section of the firing line just ahead of the spark will tell you what's going on in the primary side of the system. The spark line in the firing section after the spark occurs will tell you what's happening in the cylinder and coil.
Misfires can be seen by observing a secondary parade pattern that shows the firing lines for all the cylinders on one trace. The peak firing voltage for a misfiring cylinder with a shorted plug or plug wire will be lower than the others. But don't forget that low compression and an overly rich fuel condition can also cause the same kind of readings.
If a normal or lower than normal firing voltage drops even lower when the throttle is snapped, it may indicate a plug wire that is shorting to ground.
If one of the peak firing voltages is spiking significantly higher than the others, the misfiring cylinder may have a bad plug wire with excessive resistance, a badly worn spark plug or a plug with an excessively wide gap. Lean fuel conditions can also cause firing voltages to jump.
Note: if the spark burn lines for all the cylinders are higher than normal (indicating a lean fuel mixture), the underlying cause is something that is affecting all the cylinders. This could be an intake manifold leak, leaky vacuum hose, leaky EGR valve, leaky throttle gasket or low fuel pressure (weak fuel pump or bad pressure regulator).
A rich fuel mixture in an individual cylinder is less common, but can occur if the fuel injector leaks. A more common condition would be a rich condition in all cylinders caused by a dead oxygen sensor or coolant sensor that prevents the computer from going into closed loop, or a faulty fuel pressure regulator that feeds too much pressure to the injectors.
Something else to look at in the spark burn line is the amount of "hash" it contains. A good cylinder will show a relatively clean line with little hash. A lot of hash, on the other hand, occurs when ignition misfire or lean misfire are present.
The duration or length of the spark burn line can provide more clues about what's going on inside the cylinder. The duration of the spark line for a "good" cylinder should usually be 1.3 milliseconds or longer at idle with a .045 to .050 inch plug gap. A shorter spark line would indicate a weak spark possibly due to a lean fuel condition (dirty injectors or vacuum leaks) or low compression (burned exhaust valve or bad head gasket). If the duration of the spark line is longer than about 2 milliseconds, the air/fuel mixture is running abnormally rich. If the burn line is shorter than about 0.75 milliseconds, the cylinder is running too lean.
The last thing you want to look at in the primary ignition pattern is coil oscillations. If the coil is good, there should be at least two and preferably three or more oscillations after the burn line. Fewer oscillations would indicate a faulty coil.
[h=5]More Checks[/h]Hands-on checks you can make include removing and inspecting the spark plugs, plug wires, and ignition coil (and cap and rotor if the engine has a distributor). Look for obvious problems such as worn or fouled spark plugs, cracked insulators, loose or damaged plug wires, and cracks or carbon tracks on the coil, rotor and distributor cap. If a spark plug is wet when you remove it, it probably isn't getting any spark.
If the firing voltage is low (weak spark), measure the coil's primary and secondary resistance with an ohmmeter. If out of specifications, replace the coil. Also, make sure the coil is receiving normal voltage from the PCM or ignition module. If low, check the charging system for anything that may be reducing the alternator's output (battery and alternator cable connections, ground connections, and voltage output).
Low coil output can also be caused by a faulty ignition module or a faulty coil driver circuit inside the PCM. A lot of coils are replaced unnecessarily because problems like these are overlooked or misdiagnosed.
Simple checks that can be made to identify a misfire caused by a fuel delivery problem include checking the injectors and fuel pressure. Are the injectors getting normal voltage? Is the PCM driver circuit energizing the injectors. You should hear a buzzing noise if the injectors are pulsing. A test light or logic probe should also flash when connected to each injector circuit.
You can also observe injector performance on a scope, and check its response to changes in the air/fuel mixture. First of all, a flat line would tell you the injector is dead or is not receiving voltage (depending where the line falls on the screen). If the injector is working, the line should drop when the injector turns on, then peak when the current is switched off.
The injector scope pattern will tell you how long the injector is on. If you make the air/fuel mixture artificially lean by momentarily pulling off a vacuum hose, and/or artificially rich by feeding some propane into the manifold, you should see a corresponding change in the injector on-time as the computer responds to input from the oxygen sensor. No change would tell you either the O2 sensor is dead or there's a problem in the computer.
Injectors can also be checked with an ohmmeter with the engine and ignition off. If resistance is not within specifications, you've found a bad injector that needs to be replaced. Over time, the insulation around the injector coil can corrode causing the coil to short out. Depending on how the PCM driver circuit is wired, a shorted injector may kill all the other injectors, too, so it's important to figure out if the problem is the injector(s) or the PCM.
Dirty injectors and low fuel pressure can also starve the engine for fuel and create a lean fuel mixture that misfires. If fuel pressure is within specifications, the fuel pressure drop across each injector should be tested to see if one or more are clogged. There are some really cool testers available for doing this that will automatically test each injector without having to remove the injectors from the engine. This can be a real time-saver when injectors are hard to reach.
If a lean misfire condition is due to dirty injectors, cleaning the injectors on or off the engine may solve the problem. If the injectors fail to respond to cleaning, they will have to be replaced.
[h=5]Compression[/h]If ignition and fuel delivery appear to be okay, that leaves compression (or the lack thereof) as the underlying cause of the misfire. The air/fuel mixture won't fire normally if compression is leaking from the cylinder due to a burned exhaust valve, bent valve or leaking head gasket.
A leakdown test or cranking compression test can be used to see if the cylinder is holding or pumping up normal pressure. Low or no compression in a cylinder means the head will have to come off so the leaky head gasket or bad valves can be repaired.
Another reason for removing the head is if you find spark plugs that are heavily fouled with oily deposits. Oil leaking past worn valve guides is usually the culprit here. Installing new plugs will cure the symptom but not the cause. The permanent fix is to replace or reline the valve guides and to install new valve guide seals.
A spark plug that shows heavy whitish to brown deposits may indicate a coolant leak either past the head gasket or through a crack in the combustion chamber. This type of problem will only get worse and may soon lead to additional problems if the leak is not fixed.
A cylinder also won't fire normally if the valves are not opening and closing properly due to a weak or broken valve spring, or a rounded off cam lobe.
