ThePhoenix98
Ok, if anybody has been following the saga of my 03 GP GT. Turns out the transmission
settings were setup to run a GTP transmission with 2.93's. Mine is a GT trans. With a
PT we set the trans back to 3.29's and changed up the adapts. drove great...
Problem now is it is only showing that i was making only 4 lbs of boost. Got a code
for P0171 and P0102. System 1 bank lean and maf voltage codes respectively. Replaced
the maf and sealed up the only vac leak with some rtv. LTFT's were 16.4, im guessing
because of the leak now are around -23 at idle. the p0171 went away, but the p0102 is
still there. pulled fuse 21 and it was still good.
Cannot get into it WOT without it cutting off, yet when it cuts off it does start right back.
i have replaced damn right everything short of the fuel pump. I got another set of injectors,
should i throw them on(stock). just dont know where to turn at this point.
