Airbag codes B0026 B0044
area56
I changed the both front airbags/seatbelt buckles/airbag module and the complete steering column(clock spring) out of a 2007 GP hit in the ass-end. The airbag light went out till the next morning and the seatbelt light never went out. So what is giving off these codes?
B0044 Left Front/Driver Frontal Deployment Loop Circuit
B0026Left Front/Driver Frontal Deployment Loop (Single Stage or Stage1) Open
change the airbag module under the pass seat?
the radio controls on the steering wheel work? if not you got a bad clock spring in the new column. or you unlocked the wheel and spun it round like an amusement park ride.
both of these can cause the open loop driver side codes.
I had my seatbelt light on on my 07. I unplugged the single wire plug in under the seat to make the light go out. Something in the buckle itself went bad.
