jasonnovak
After replacing the SRS bulb in my recently acquired 99 GTP I've discovered my air bag light is on. It blinks 7 times and then stays on.
I know it was in an accident in the past, and checking the driver airbag I saw the bag connector was cut in the wheel and was twisted and taped back together, and the thing for the passenger side spliced behind the radio. Must have done it when putting new ones in, not sure why? I re-did them, did test the continuity of the driver side so I know the clock spring is good.
Is the only other option the module (SRS fuse is good)? I heard from the previous owner it did get wet from the previous owner, but when I peeled back the carpet it actually looked pretty clean and no signs of rust on the sheet metal, though the carpet is fairly stained (water or just dirty?).
