agx vs bilstein
06PONTGP
I am getting good reviews on both but bilstein are a bit more.....is it worth it? and got ssc lowering springs to go with which ever....can get agx for about 150 a strut and bilstein comfort for 170 a strut or hd for 230 and that is all new i have a guy with a set of 4 off of a gxp so i think they are comfort for 400 but they have 40k and you should replace every 60k its a toss up alot of money at stake
If you have an 06 then just go with the agx.. the bilstiens are a little more superior but most people with pre 04 gps run the AGX with lowering springs and have no problems with ride comfort.. its really up to you if you want to spend the money
Correction: i was also talking about the HD Bilsteins not the low models..
And also just double check to see if you have the corrected LCA to strut set-up inorder to run the AGX's
