Regalgse00
Who's got them and how do you like the ride. And anyone running zzp control arms?
Considering the coilovers are inserted into the housings basically why hasnt anyone else used something that wont blow out or has a longer stroke to the strut maybe koni or some other brand. Obviously this wouldnt be for the vendor coillvers but the DIY guy i would have thought by now something better than agx would have been used.
you'd want a shorter overall body, which in turn would have a shorter stroke.
but "no one has found" a strut that'd work.
i would personally just buy a set of coilovers that were for another car, then modify the mounting points so they worked.
buy a set of BC coilovers for $900 from a car that has a similar suspension, move/modify lower mount as necessary to bolt up to the knuckle, then modify the upper mount to either accept the stock GP mount (rubber mounts bad, no no) or make it so the studs are in the correct spot (hint: make a new top half of the pillow ball mount).
Where did u get the bilstein coilovers from?
W-body's are dead, no one will develop new struts/suspension for this car now.
