Aftermarket Head Unit Wiring Help?
beams75
-2006 GP, Monsoon System
- I'm not asking about what components I need.
Yellow (from car out) to Yellow (radio in) for power.
ALL RCA's are hooked up
I'm confused on where the blue/white wire goes, and even confused on where the red wire (Ignition) goes.
I have power to the head unit, but no sound output. I know my explanation isn't the best but I really suck with wiring. I've installed two head units before on other makes and models but this is BY FAR the most over complicated and so fat it's winning :(.
Any comments or insight would be appreciated.
red wire of adapter goes to radio ignition wire most likely also red, blue/white wire goes to amp turn on wire from radio make sure it is not power antenna lead most likely also blue wire
well i went with a normal harness, not the gmos04. i gave up, so i took it to a shop around here, they tried for an hour and couldnt figure it out. thanks for the help though
I had the same problem when I bought my gtp. After playing around with it for countless hours I took it to a shop. They determined the monsoon amp was bad and bypassed it.
