Aftermarket cooler
looks like the cooler is leaking, see how the fins are all wet too. if its the only cooler being used, just replace it. they are rather cheap. hayden 24,000 gvw can be found for like 40 on ebay.
if its the hose spraying, take the hose off, cut the end of the hose off and put it back on, use some degreaser or brake cleaner to clean it up and watch for a leak to form. no leak and you fixed it.
i knew there was a reason to hard line that all in. never liked rubber hose. the ends tend to get used up, becoming soft and fail to seal well. cutting off a inch or so will get you to better hose, then try double hose clamps.
i got one mounted but not plumbed in yet, ive wanted to hard line it the whole time too. now im gonna try my best to not have any rubber hose.
