Acid's 2005 Top Swapped GT: S2X Cam Install
acidcrashdburnd
Figured I make one of these threads to track all progress that will bring my car in the 12's
Installed Mods
Powerhaus Performance Dyno Tune
19* of timing
FWI
Self Ported Heads, 105# Comp Springs,
ZZP Ported LIM
SSAC Headers, Dynomax Super Turbo Mufflers, No Cat, Factory Res.
180* Self Drilled T-Stat,
NGK TR55 / Belden Wires,
SSC 1.8 Springs w/ Monroe Sensatrac Struts, GMPP Trailing Arms,
3.0 Intense MPS
ZZP SSIC
INTENSE S2X
60# Injectors
Devils Own Meth Injection
TEP Shift Kit
Easy Performance Fan Speed Switch
Powerstop Slotted/Drilled Rotors,
Front: BF Goodrich KDW 225/50ZR16 on factory 5 spokes
Rear: Uniroyal Tigerpaw GTZ 225/50ZR16 on factory 5 spokes
I think it was around 101*F when this video was taken.
Audio Mods!
AudioQue 1200D
x2 AQ SDC2.512's
Kinetik HC1200
Kicker 400.4
Infinity Kappa front and back.
Alpine iDA X001 HU
Now picture time!
Just home from the stealership.
My moms 2001 GTP in the background.
Friends 2001 GTP 3.5 pulley HAI..
91.2lbs subwoofer box I had to remove the backseat and cut metal to make fit.
The old top end
Re: Acid's 2005 Top Swapped GT
Putting the exhaust on July 2009?
Blizzard 2009-2010
Right after lowering
Accident :(
Moar parts
SSAC Headers
1of2 bent valves from the L67 Heads I bought.
​WEIGHT REDUCTION
Re: Acid's 2005 Top Swapped GT Moar parts coming.
Your cats on your chairz, guardin yer parts
Hope you friend running that 3.5 pulley has real supporting mods for that pulley drop besides a "HAI".
Looks good but one thing I hope you invested in is something to scan like aeroforce scan gauge.
Thanks, Right now I am scanning using Torque for Android. Seems to be doing pretty well. I scan for KR and fuel trims mostly for that and commanded AF.
Working on getting a cheap AEM WB.
Oh yea get a WB to..if or when you have the funds invest in the Aeroforce though. You'll really appreciate it more then the torque app. Oh and with the Nic cam you may want to check w/ Drunkie I think he mentioned MPG wasn't that great. If that's a concern I would go w/ either VS/SIX or XP.
Re: Acid's 2005 Top Swapped GT: ZZP SSIC Bought.
nice man! we have the same headunit fyi...you can change the color to red (as well as the backround on the mini screen)
Hooray for early adopters lol. Mine is set to red and I found a Pontiac background for it but it looked like ass
Sent from my Galaxy Nexus using Tapatalk 2
nice ride the heads are nice! did you do the top swap yourself? and whos 67/68 Mustang next to the lift and your car
