Linky Linky
the engine will not be running. the extra quart you put in...goes straight to the pan. thus will push most of the old oil out. you can put your new filter on....just make sure you put some new oil in the filter before you put it on..so motor isnt fully dry on start up...and make sure you oil the rubber seal on the top. a little dab of new oil..and wipe it all around with your finger...until it is coated. Make sure your old filter came off with its top seal, if it is still on the mount, take it off, otherwise you will double seal it and it will spray out oil. then screw it on (as tight as you can get it with your hands) and there ya go.
add oil, check it.....have some fun!!!
now for oil. if it was straight synthetic in the car before..use synthetic now. you cannot go straight from synthetic to regular....without hurting the engine a bit...as the two oils do NOT mix. you can use straight synthetic, then a synthetic BLEND, and then the next you can use normal. that way it gives the seals, and metal surfaces a chance to be reconditioned to the oil.
but you can use synthetic anytime after...you just have to gradually step it back down to normal after that.
if it is cold where you are use 5w30...as it will give better lubrication in the winter because it is thinner. in summer step it up to 10w30....it does not break down in summer do to heat..... also....look for an oil that offers the best phosphorus/zinc content. I use Mobil1, AmsOil, or Royal Purple(all synthetic). these 3 have the most (thats left) of a normal passenger car oil. the delvac, and Rotella Diesel oils..are great for breaking in an engine, but toooo thick for daily use.
I can go on for hours about oils....as I did a lot of research when I found the best oils to break in my GTP engine....
now I sound like Scotty!! lol!!!!
PS: also for filters...you can use the filter from a 98 Blazer(4.3L), longer and offers more oil filtration..not sure if the PF52 is the stock size or not...been a while since I have bought any other oil filter than a Mobil1.
