AC delete pulley
98gtpinaz
So I was wondering what everyone was doing with AC if it's being removed...I want to eliminate the compressor as dead weight now since all mine is yanked and want to either just remove and run a smaller belt or use a dummy AC pulley...
What is everyone's suggestion on the topic?
Theres a pulley that you can buy from nearly any auto parts store.
I do have trouble believing you are in Tucson and wanting to delete ac though. You must like that "dry" heat.
the geometry is wrong to just run a shorter belt, it will end up hitting on something, so you have to use the ac delete pulley.
Ok AC delete pulley it is...it's not a daily so freeing up as much as I can...AC didbt work when bought the car so pulled all the lines, heater core, controls, and all that fun stuff only thing still there is the compressor and wanted to save the weight there...
